Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Neff S51L43X0GB mystery leak (E15)
- This topic has 6 replies, 2 voices, and was last updated 5 years, 10 months ago by
PeteWilliams.
May 27, 2020 at 8:55 pm #97701
PeteWilliams
ParticipantHi,
Our S51L43X0GB came up with an E15 the other day, I took the small panel on the front off and could see/feel a small amount of water in the base (unplugged first, obviously!).
I tried it out what I could with a tea-towel and left it overnight to dry out more.
In the morning the error was gone and I re-ran it, but after a few minutes the error came back.
I’ve just taken the washer out, tilted it out to get the water out (a very small amount) and re-run it.
I’ve spent the last 40 minutes lying on the kitchen floor with a torch peering through the front for any leak, but can’t see anything and so far it’s run for an hour or so without any error.Are there any common issues I should be looking out for that might cause a leak? Any seals worth replacing even if I can’t see the leak…?
Pete
May 27, 2020 at 8:56 pm #469089PeteWilliams
Participant‘dried out’ not ‘tried it out’!
May 27, 2020 at 11:16 pm #469090electrofix
Moderatorhave had them leak between the plastic tank base and the stainless sides
May 28, 2020 at 8:43 pm #469091PeteWilliams
Participantelectrofix wrote:have had them leak between the plastic tank base and the stainless sides
Being an integrated unit, it doesn’t have sides, it’s just exposed insulation – if those are the sides you mean?
It stopped again today, but I couldn’t see where the leak was coming from. Pretty difficult just looking through the gap where the panel was at the bottom front – is there a better way to get a look/diagnose the issue?Thanks
May 28, 2020 at 8:46 pm #469092electrofix
Moderatoryes take it out
remove the lower covers from each side
and re connect power and water pipe and run itDave
May 31, 2020 at 11:34 am #469093PeteWilliams
ParticipantSo I’ve removed the three lower covers run it and had a look. It’s still leaking but I can’t see where from – there doesn’t appear to be any dripping, a puddle just appears.
Can anyone suggest any specific areas it might be coming from?
May 31, 2020 at 11:46 am #469094electrofix
Moderatorit has to be dripping from somewhere you just have to be at the correct angle at the correct time to see it
dave
