Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Neff S51L58X1GB/35 dishwasher PCB blown
- This topic has 7 replies, 3 voices, and was last updated 9 years, 2 months ago by
Twoten.
January 28, 2017 at 1:21 pm #90457
Twoten
ParticipantI went to a dishwasher that is dead.
The main chip on the PCB and one of the small IC’s has blown.
I have tried to trace the fault back but following the tracks doesn’t lead directly to any components.
Has anyone seen damage to the same area and traced what could have caused it?January 28, 2017 at 2:16 pm #444863electrofix
ModeratorRe: Neff S51L58X1GB/35 dishwasher PCB blown
looking at that i would guess possible water damage
none of the track seem to lead out to any component and if they did and that components had failed i would expect 1 or 2 blown tracks but you have had a full blown fire in one place
dave
January 28, 2017 at 5:53 pm #444864Twoten
ParticipantRe: Neff S51L58X1GB/35 dishwasher PCB blown
Thanks Dave,
I wasn’t sure if the fire caused the IC and chip to blow or the other way round.
There are no obvious signs of water ingress however it’s possibly a water mark on the solder joint to the right of the burn mark.
It transpired when I got to this machine that it’s still under warranty but wanted to try and find out the likely cause for my own satisfaction.January 28, 2017 at 6:49 pm #444865electrofix
you can never rule out condensation in boards that are mounted at the bottom of the machine especially in old cold property
January 29, 2017 at 10:04 pm #444866Twoten
Conditions in this kitchen didn’t seem to lend themselves to condensation (unlike some I’ve worked in) but definitely worth considering.
Thanks for the input Dave.
February 7, 2017 at 12:17 pm #444867Twoten
Just to give a final update to this;
BSH looked at the machine and felt it might be caused by water so they are replacing for the customer.
Thanks for the advise Dave.February 7, 2017 at 5:19 pm #444868Martin
Twoten wrote:BSH looked at the machine and felt it might be caused by water so they are replacing for the customer.
Water from where that BSH felt responsible enough to replace it? Are we talking design fault here that BSH are quietly swapping out?
February 7, 2017 at 7:11 pm #444869Twoten
As I mentioned before “there are no obvious signs of water ingress however it’s possibly a water mark on the solder joint to the right of the burn mark”.
There were no other indications of damp or moisture, the insulation pad alongside the PCB was also dry. The PCB case is well enclose so the most likely cause as electrofix suggests would be condensation but there wasno indication of this other than the mark on the PCB.
Maybe there is a design fault, it would be interesting to know. -
