NEFF S51M53XOGB/16 Totally dead
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries NEFF S51M53XOGB/16 Totally dead
  • #82543
    chitts
    Just been to look at this machine. Power to the machine, wiring tests OK, On/Off switch OK. Can’t test the door switch as its a sensor type. Anyone had any problems with these? The machine is 4yrs old and only used twice a week, I hope it’s not the board!
    Any clues would be welcome.
    #420195
    Re: NEFF S51M53XOGB/16 Totally dead
    I doubt problems with the door switch as that doesn’t come into play until after you set the programme the press start. More likely the PCB or perhaps just a wall socket fault? Have you dragged the beast out for a look around the back?
    #420196
    chitts
    Yes Martin, had module out too, and couldn’t SEE anything wrong. All points to the board, but trying to eliminate everything I can.
    #420197
    smeghead
    had one of these a few months ago, did same fault finding as yourself, once you rule all the obvious out , only leaves the board dunnit? The only problem is did another component cause the board to go ?
    Anyway after quote she bought new m/c , so now I’ll never know. Bu***r.
    Clive
