Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Neff S51T69XIGB/01 Dishwasher FD8803
- This topic has 8 replies, 6 voices, and was last updated 14 years, 5 months ago by
mike412.
October 20, 2011 at 4:13 pm #65778
mike412
ParticipantThis dishwasher makes a grating noise when the circulating pump is running, probably a small piece of ceramic in the impellor as I found a small piece in the sump also. Not seen this model before, it has a small, mostly plastic motor, a bit like an up market Askoll. Any tips on removing this motor for accessing the impellor? Looks like it could be a tank off job to me.
All replies much appreciated.
Mike.
October 20, 2011 at 6:46 pm #361821weekiteman1r1
ParticipantRe: Neff S51T69XIGB/01 Dishwasher FD8803
Not seen that model before. Sound like a newish shape machine. Will keep an eye on post to see how it goes but if its anything like the askols on the whirlpools, (the new snail type heaters directly on the wash pump) impellars are usually simple to remove but blades shearing off common.
ScottOctober 20, 2011 at 6:53 pm #361822BobHope
when i come across noisy wash pump and i think something may be in it,the first thing i do is remove the spray arms and start a programme, the fast flow rate sometimes flushes it clear.
Bob.
October 20, 2011 at 7:09 pm #361823RocketMan
ermm not seen any of these yet. The motor is a heat pump not sure how to get access though… will follow for interest.
PS model is S51T69X1GB/01 (figure 1 after the X not i)… just put this here for future searches.
Please let us know how you get on…
Ta
October 20, 2011 at 8:42 pm #361824nomadPaul
Is it making the noise constantly or briefly every 2 minutes or so ?
October 21, 2011 at 7:35 am #361825mike412
ParticipantRe: Neff S51T69X1GB/01 Dishwasher FD8803
Noise is there “most” of the time.
I like Bobs idea of running with the spray arms off, got to be worth a try. I was hoping one of our Bosch friends might be able to help with some bedtime reading- any chance.Regards,
Mike
October 21, 2011 at 8:32 am #361826Martin
I think you’re gonna have to pull the circulating pump out Mike as see. Not fixable mind, will need replacing (Part No 647397) don’t forget to order a jubilee clip (172272) as well, you’ll need it. 😉
October 21, 2011 at 7:42 pm #361827mike412
Thanks Martin.
Is this a “Tank Off” job, in the manner in which you have so clearly described for the earlier models, or can it be pulled from the side ?.
Mike.
October 21, 2011 at 9:37 pm #361828Martin
No it comes out the front without tub removal.
