NEFF S52M69X1GB/16 E24 FAULT CODE
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries NEFF S52M69X1GB/16 E24 FAULT CODE
  • #76137
    We have above dishwasher, E24 fault code – no draining I understand. Appliance drains well, so we replaced the sensor in the sump, but still gives the error. Need to understand how the dishwasher determines when its empty?
    Thanks,
    Alister
    #397365
    Re: NEFF S52M69X1GB/16 E24 FAULT CODE
    Drain sequence timed only. Check the resistance of the pump windings.
    #397366
    Thanks Martin,
    will do – thanks for the advice
    Alister
    #397367
    wizard
    Most lilely something wrapped around the pump, easiest to take it out and look at it as its not easy to see when it is in the machine. I’ve had butcher’s string, dental floss, elastic bands around them. Wiz
