Re: Neff S5433X0GB/13
Toni wrote: but I am not sure about the aqua stop device. will this need to be replaced also ? or can they be reset.
The solenoid valve within the aquastop unit may have become open circuit? To reset the aquastop water block device simply requires the water turning off, the coupling loosened to allow it to vent, then reconnect and turn the stopcock on again.
Once you’ve cleaned and/or replaced the Pressure Chamber and transfer hose and the base is clean, dry and ready to go. Reset the programme module and hopefully it should burst into life again.:wink:
I did have one once (not same model but close) that would not fill and oddly enough it turned out to be caused by the drain pump. The wires were linked and the coil was drawing too much current – quite a headscratcher that turned out to be let me tell you. :rolls: Hopefully your pump is working fine?
