neff s5433x0gb/17
  • #9848
    hi,
    i have a fault with this dishwaser the drain motor is always running
    even with the door open?
    i have tried the reset and power off but i can not get the machine to do anything apart from drain?
    thank you for any help
    shorko
    #136357
    Re: neff s5433x0gb/17
    shorko,
    The problem with your machine is that the base (not the tub) of it has flooded with water and the flood protection device has activated. The reason is that there is an internal leak within your machine somewhere that needs sorting?
    Best call in a local independant engineer to fix it for you I reckon. Try this link to see if we have one in your area :Repairs@
    #136358
    thank you martin for your reply
    how do i get to this?or is it best to get a
    dishwasher repair man in?
    ps i can not see any leaks
    thanks again
