The only source of constant noise will be the circulation pump. The Neff repair would be a new motor (£115). Usual cause is water leaking from the pump seal into the front bearing, so a seal kit at the same time would be advisable; about £30. All plus VAT etc.
If you would put up the rest of the model number (GB/–) I can identify the parts required exactly.
