Neff S5443 poor water circulation
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff S5443 poor water circulation
  • #30305
    Seamy
    Have to look at one of these 5years old (Integrated Neff S5443x2 GB17) dishwashers. Customer reports hardly any noise out of it & if they open door theres hardly any spray from spray arms at all, it does fill ok, filter in sump is clean. Do motors or capacitors give problems? I’ve looked at Connect & they list a circulation motor only ( not pump section) for £88.
    #226712
    stu123
    Re: Neff S5443 poor water circulation
    on some models there is a half load valve but generaly poor wash results are the complaint
    #226713
    Seamy wrote:Do motors or capacitors give problems?
    They either work or they don’t, usually the pump leaks into the shaft bearing and the whole lot seizes up. Prior to that happening the machine gets very noisy of course. 😉 Capacitors give no trouble in my experience.
    Pump impellors never fail as a rule except when something like a teaspoon finds its way into the entry pipe, or pheasant was on the menu the night before and lead shot has buggered it up :rolls:
    Seamy wrote:Customer reports
    Yeah right… :rolls: Ask them the time of day and they never get it wrong but ask them what’s wrong with their machine ….??????? 🙁
    #226714
    superfix
    Check the sump hose and pressure chamber.
    #226715
    gegsy
    …….and also faulty water point unit on heater and/or module. 😀
    You have mail seamy 😉
    Seamy
    Greg, many thanks for e-mail,
    #226717
    gegsy
    Most welcome 😉
    clivejameson
    Sounds more like the impellor has sheared 😕
    If you’re very lucky the shaft won’t be too rusted so you won’t need a new pump….just the impellor kit, but i’ve done a handful now and only one didn’t need a new pump despite attacking them with a wire brush 😯
    Impellor kit is 183638
