NEFF S5443X1GB/07 – Leaking from door.
Home Forums Public Support Forums Help And Support Dishwasher Help Forum NEFF S5443X1GB/07 – Leaking from door.
  • #24993
    PDPS
    I’ve been asked to sort out a problem with a leaking dishwasher (make and model as in the subject).
    It’s losing about a mugful of water, from the bottom left corner of the door, during each wash. I suspect the seal along the bottom edge of the door as it has a couple of ‘bumps’ where it appears to have worked loose from where it is clipped in. I’m also wary that it could be a problem around the soap dispenser – although this looks to be in good condition.
    Any thoughts?
    #204090
    Re: NEFF S5443X1GB/07 – Leaking from door.
    Door seal good bet – p/no 298534 – spares@ukwhitegoods.co.uk will get you one quickly and at a good price.
    Also, check bottom rotor very carefully for splits – weird watery things happen if it has.
    Fairdeal
    I had to change couple of these seals.You will probably have to change the door bottom seal.
    But still check the dispensar area to be sure
    By putting the old one back it came out after a while so I had to change the whole seal and it is not expensive.
    Regards
    #204092
    :waving:
    :p45:
    #204093
    PDPS
    Many thanks.
    Customer informed – now I just wait while their timber floor gets soggy under the vinyl that’s already lifting. Shame about the ceiling in the flat below … 😕
    #204094
    nomadPaul
    i have had a couple of appliances where the customer has leant on the dishwasher door whilst its in a level position and this has caused the inner door to bend by the hinges . This can cause a gap to appear between the door and tub edge . ould be worth checking out as well.
    #204095
    PDPS
    nomadPaul wrote:i have had a couple of appliances where the customer has leant on the dishwasher door whilst its in a level position and this has caused the inner door to bend by the hinges . This can cause a gap to appear between the door and tub edge . ould be worth checking out as well.
    It’s an old machine in a rental flat so anything could have happened – although the current tenants seem very responsible and are looking after the place well.
    Thanks for the tip – will check it out if I get the job.
