Neff S5443X1GB/13 Dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff S5443X1GB/13 Dishwasher
  • #8998
    Toni
    Hi all
    I have a strange fault on this dishwasher, the fault is that the machine drains very slowly. I have checked & replaced the pump, there are no blockages in any hose or sink waste & the little rubber flap by the pump is clean. The water just trickles in to the side metering tank from the pump.
    Any ideas?
    Regards
    Toni
    #131568
    Re: Neff S5443X1GB/13 Dishwasher
    Toni,
    With the pump cover removed you should be able to blow through the entire drain system from the end of the drain hose. If not, it’s blocked somewhere down the line. Also with the pump cover refitted and a tub of water at the ready, disconnect the drain hose from the metering tank and hit the switch, if that drains OK then the Metering Tank is blocked somehow ❓
    Most popular blockages are bits of plastic wrapping from Dishwasher Tablets, had several instances of those 😉
    Toni
    Thanks Martin, Iam going back to the job tomorrow am.
    Will let you know
    Toni
    #131570
    Little bits of glass in the drain matrix down tube – a regular invisible problem.
    sene
    Toni,
    I suppose you are taking all this in, but have a look at the left side fill chamber, remove the black rubber, you have two options, one goes to the drainage, the other from the pump. Take second option first, ie from pump, put the little hose into container or what ever, set machine to drain, if ok the the blockage is at the other side etc etc etc………etc
    good luck 😆
