Neff S5443X1GB/17 – Does not finish cycle
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Neff S5443X1GB/17 – Does not finish cycle
  • #100017
    A42
    I have a Neff S5443X1GB/17. It pumps out the water at the end of the cycle ok, but the (or a) motor carries on running (until I open the door). It does not move on to the fill cycle, even if I press the Reset buttons. If I add more water from a bowl, it pumps it out again (as soon as I close the door and if the on button is pressed in). Since this happened, I’ve not been able to get it to move on (from the pumpout stage) to start a new cycle.
    The base does not seem to be flooded and the red float switch at the front left is not raised.
    I was wondering, is there a (low water) sensor to tell the machine when the water has all been pumped out? Where is this located? Thanks
    Any thoughts would be appreciated.
    Thank you
    Andy
    #478910
    a lot of later machines monitor the current drawn by the pump to determine if its empty
    A42
    Thanks Dave, that is very useful… so maybe a new pump or a new circuit board? I am told this machine is around 20 years old…
    #478912
    cant see it being 20 but you never know
    let me have the FD number and i will tell you exactly
    A42
    FD:8007 Thanks
