Hiya,
I have the above dishwasher and initially it would not drain and was leaking from the bottom seal. It filled fine, heated fine but just wouldn’t pump out. I manually drained it, removed filters and pump cover, soaked up all remaining water and found nothing jamming the pump.
I have replaced the seal and the pump (that was not an easy job! what’s the easy way to fit a drain pump on it?)
I put a couple of glasses of water in the base and I ran it and the drain pump kicked in straight away but carried on running when I opened the door?
Would I be correct in assuming that the PCB is at fault?
Your help would be really appreciated
