Neff S5443X2GB/17 door adjustment
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff S5443X2GB/17 door adjustment
  • #44758
    monkey
    Hi guys
    can you adjust the tension for the springs on the door it drops down to fast with the decor door on. All the cables and springs are ok.
    #282208
    nomadPaul
    With the install kit , there should have been two biggish screws/bolts . These fit into a hole just above the feet and when screwed in , tension the door spring assembly . It is all done from the front as its clearly accessible . Does the customer still have the installation sheets as it should be shown on there ?
