Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › neff S5444X1GB/22 wont finish cycle
- This topic has 12 replies, 2 voices, and was last updated 13 years, 10 months ago by
slyp98.
May 16, 2012 at 10:00 pm #69516
slyp98
Participanthey guys , i have this customer 40 min drive away , sayes this d/w is acting up , puts it on at night and it starts fine but in the morning the pump is running still , just a few ideas if anyone has worked on these what to expect i’m not goin back again so im bringing a pump , wash pump seal , flow meter anyone know what else is likely to cause this cheers k
May 17, 2012 at 7:23 am #375048Martin
ParticipantRe: neff S5444X1GB/22 wont finish cycle
It sounds like a straight forward flooded base to me. So, leaking circulating pump, impellor jug, knife fork or spoon caught under the float or leaky heater?
May 17, 2012 at 7:33 am #375049slyp98
cheers Martin , i dont have a heater box so fingers crossed it aint that
May 17, 2012 at 1:00 pm #375050slyp98
had a chat with the customer , he sayes no water in base and he ran it empty so nothing stuck in float safety switch , too much water coming in ? activating the float inside ?
May 17, 2012 at 1:26 pm #375051Martin
Participantneff S5444X1GB/22 wont finish cycle
slyp98 wrote: he sayes no water in base
No, no! I refer NOT to the bottom of the tub but the baseplate (I.e. flood safety switch activated)…that’s your problem….go for it!
May 17, 2012 at 4:42 pm #375052slyp98
yeah thats what i meant Martin , i got him to take off side panel base clear of water
May 17, 2012 at 5:12 pm #375053Martin
slyp98 wrote:yeah thats what i meant Martin , i got him to take off side panel base clear of water
That’s odd then, how come? This is a plastic tub model with removable bottom plate. :con:
May 17, 2012 at 8:44 pm #375054slyp98
yeah he said there were half panels on each side one torx front and back and it was off , dry base , i dunno what else it could be only that it takes too much water , and the level inside the tub is too high ? . if it did would the switch inside activate ? he sayes it looks like a mushroom , but when the level goes back down would the switch not reset to normal position and stop pumping out? i dunno i guess i’ll just drive up there
May 18, 2012 at 8:13 am #375055Martin
slyp98 wrote: i dunno i guess i’ll just drive up there
Your customer sounds like a right DIY bodger so don’t be too surprised at what you find when you get there. All the ruddy panels off indeed, and all that messin’ with mushrooms, makes for a fun visitation I shouldn’t wonder. 😀
May 18, 2012 at 11:53 am #375056slyp98
true indeed , ill hold me breath goin in
June 26, 2012 at 12:26 pm #375057slyp98
replaced the jug impeller as it was taking for ever to fill, now wont heat water no power going to the element , board fault i suspect !!
June 26, 2012 at 6:31 pm #375058Martin
Taking forever to fill is a major issue here TBH. It has to fill in a reasonable period (i.e less that 2 mins) for the PCB to compute its next move. So at this point I don’t suspect the PCB. So, is there a water pressure problem there?
No heat is easy to resolve…..either the element is o/circuit, or the flow micro switch on the heater box hasn’t activated due to low flow water pressure or the PCB is at fault. (As a rule it’s just a solder job on the PCB relay contact that’ll sort that anyway)
HTH?
June 26, 2012 at 9:32 pm #375059slyp98
yeah the fill issue is sorted , i see some tips on here about a relay on the board need a solder repair cheers
