Neff S5453X0GB/17 Dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff S5453X0GB/17 Dishwasher
  • #72484
    mjhservices
    Starts pumping for 5 – 10 seconds, stops and displays “F”
    Checked for earth leakage – none
    Checked water valve pump motor element etc all okay.
    Must be a fault with the circuit board????
    Anyone had this fault??
    Regards Mark
    #384641
    Re: Neff S5453X0GB/17 Dishwasher
    “F” is the proverbial FILL error. So it’s either a faulty aqua stop valve or a flow problem of some kind as a rule.
    #384642
    mjhservices
    Thanks Martin
    I did check the resistance of the water valve and that seemed ok and there was a supply of water so do you think its still the valve?
    The “f” fault came up so quick before it could work out if the valve would work or not!
    Mark
