Neff S5453X1GB/50 No Start
  • #79601
    allan73
    The above dishwasher does not start up when door is closed but an audible click can be heard from module then nothing.
    On/off switch and door microswitch look ok, no evident burn marks on module.
    Shall I order a module ?
    Allan.
    #409947
    Re: Neff S5453X1GB/50 No Start
    If you lift the anti flood lever will the drain pump work?
    #409948
    allan73
    Haven’t tried to be honest Martin. What would that indicate ?
    Allan
    #409949
    Well the first thing the machine should do is pump. So lifting the float switch should operate the pump so a pump fault has to be eliminated first. The click you hear may be the PCB trying to fire up the pump?
    #409950
    allan73
    Yes I get your point Matin. I’ll speak to the customer about going back tomorrow.
    Allan
