Neff s5453x1gb/55 just fills and drains,fills and drains….
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff s5453x1gb/55 just fills and drains,fills and drains….
  • #42713
    Johnnyboy
    I have a Neff int D/W s5453x1gb/55 that, when a programme is selected it starts to fill then after a while it starts to drain but once the pump comes on it wants to keep filling just back and forth. I replaced the lower side tank bit with the microswitch and float but now think the module controls how much water comes in as I cant find a pressure switch. How does it know how much water to take in before it starts washing??????
    Cheers folks
    #274608
    Re: Neff s5453x1gb/55 just fills and drains,fills and drains
    The float/microswitch assembly you’ve replaced is the pressure switch unit. 😀
    The symptoms suggest that the hose from that unit to the sump is gunged up that’s all? 😕
    #274609
    Johnnyboy
    re gunged up tube to sump it is beautifully clean, something must tell the inlet valve to stop and the recirc motorto start.
    #274610
    Johnnyboy wrote:re gunged up tube to sump it is beautifully clean, something must tell the inlet valve to stop and the recirc motorto start.
    Indeed and that is the pressure switch micoswitch (the top one of the two there) that stops it filling.
    Just a thought?……No evidence of mice inside the machine by any chance? 💡
    #274611
    Johnnyboy
    Sorry, no sign of mice she has 3 cats. The red float and microswitch combination is the pressure system? even mauually operating the red lever from the anti flood decice just stopped the filling but brought on the pump.
    #274612
    nomadPaul
    Classic symptons of he flow rate meter failure .
    Part No 424099 ( impellor jug – official title )
    Won’t be sending the correct signal to board
    its the ‘white wheel’ inline of the inlet hose before it reaches the water matrix
    Replace it and all should be well
    #274613
    Johnnyboy
    Cheers NomadPaul twas the flow meter first one ive come across cheers
