Neff S5453X1GB/74 Drains/fills
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff S5453X1GB/74 Drains/fills
  • #48792
    Latham63
    This dishwasher fills ok.Then at the point when it should stop it starts to drain and fill continuously.Pressure system looks clear.Could wash motor error cause this? Control board looks ok,although there are traces of something(water?) on pcb which has dried!
    Personaly suspect pcb error? Any clues??
    #297745
    adv
    Re: Neff S5453X1GB/74 Drains/fills
    the pipe from side tank . to sump mite cause this if gunked up 😆
    #297746
    Latham63 wrote:Personaly suspect pcb error? Any clues??
    I don’t, but the pressure chamber needs stripping and cleaning and the sump transfer pipe as well. 😉
    #297747
    nomadPaul
    99.9{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure It will be the impellor jug ( flow rate meter )
    Part No: 424099
    #297748
    Johnnyboy
    Agree It will be the impellor jug on the inlet b4 the chamber
