NEFF S5453X1GB/74 Int’ D/W Prob’
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries NEFF S5453X1GB/74 Int’ D/W Prob’
  • #80194
    jontymox
    Good afternoon all,
    Wondering if I can obtain any advice on a problem with the above dishwasher?
    Basically, the m/c will do the initial drain for around 30 seconds, then admit water, wash, and heat up before draining.
    However, it will not then admit fresh water, and remains in drain mode.
    I have checked for a water leak in the base, which is dry, the anti-flood device seems fine, and cleaned the pressure chamber and matrix, which were both very dirty.
    I now wonder if I should be looking at a control module fault, which, alas, I didn’t inspect on site?
    Or, should I be looking in other areas?
    The water symbol light is also illuminated.
    jonty
    #412054
    Re: NEFF S5453X1GB/74 Int’ D/W Prob’
    Clutching at straws here a bit I must confess but the Pressure Chamber microswitch could be at fault?
    #412055
    Andy jones
    Ditto martins comment
    Had exactly that problem and turned out to be microwswitch
    #412056
    jontymox
    Good evening,
    Thank you for your help,
    It was the microswitch causing the problem.
    jonty
