Neff S5456X1GB/12 dishwasher continuous pump.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff S5456X1GB/12 dishwasher continuous pump.
  • #35971
    aqualectric
    Neff S5456X1GB/12 integrated dishwasher. FD 8109.
    This machine has had the archetypal blocked fill metering system, sludged hose to sump and flooded base. The pump runs continuously – basically as soon as the machine is switched on it pumps. So I dismantle and thoroughly clean all the individual parts of the fill metering system and carefully refit it taking care to dry out the base. (float switch is at rest with no water underneath).
    So I thought, PCB. Sure enough, there was a blown solder joint on one of the legs of a 6V relay, so I am feeling confident that all is well.
    Not so – after careful soldering, the pump runs constantly: ie:- no different.
    I am pretty sure it’s the PCB that’s frazzed – any other things to look for?
    Thanks,
    Steve.
    #248910
    Re: Neff S5456X1GB/12 dishwasher continuous pump.
    Relay is usually the heater feed – triac failed open circuit?
    aqualectric
    New PCB time I think!! :rolls:
    Thanks again, Chris!!
    Steve.
