Neff S5456X3GB/24 Dishwasher Side panel leaks.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff S5456X3GB/24 Dishwasher Side panel leaks.
  • #40421
    Twoten
    Looked at the above dishwasher, found the float chamber blocked causing the problem. Lowered the ‘heat exchanger (215761) down so I could remove the chamber to clean. Rebuilt the machine to find the ‘heat exchanger unit’ now has a leak.
    On further investigation I find a really small hole in the plastic sheeting side of the chamber.
    Having looked at the price if a replacement ‘Heat Exchanger’ it might be handy if it can be repaired rather than replaced.
    Can anyone recommend the best way to do a successful repair on one of these. I’m tempted to try a n instant puncture repair patch but thought I would see if anyone here has found a better solution?
    #266137
    Re: Neff S5456X3GB/24 Dishwasher Side panel leaks.
    Araldite epoxy resin I should think would suffice?
    #266138
    clivejameson
    …or perhaps a ‘Blue Peter’ moment with some sticky-backed plastic? 😆
    #266139
    Twoten
    After chewing the gum to stick on the hole it gave me time to contemplate the situation.
    I scratched up the surface with some emery paper to give a better key then used some thin plastic sheet similar to a plastic motor cover and stuck it in place with Fernox LSX.
    LSX is great stuff, it sticks to wet surfaces like the proverbial to a blanket, remains flexible and will withstand freezing/boiling temperatures.
    Now all I have to do is keep my fingers crossed.
    Thanks for the suggestions.
