Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Neff S5457X0GB/02
- This topic has 7 replies, 3 voices, and was last updated 18 years, 5 months ago by
aahbarnes.
October 30, 2007 at 8:10 pm #31812
aahbarnes
ParticipantHi again.
My parents dishwasher this time!
It a built in Neff, 3 years old. It needs resetting before each wash or it sticks with 1 minute to go and doesn’t finish. Sometimes the dishes are still wet. Started doing this on just the auto program, now does it on all of them.
Any ideas on this one?
AndrewOctober 30, 2007 at 9:18 pm #232588gegsy
ParticipantRe: Neff S5457X0GB/02
Most likely
1/ Crud in the top of the water matrix (output ventilation valve)
2/ Transfer pipe crudded up
3/ Levelling/metering unit crudded up4/ Too little water in appliance due to 2 and 3 above
Power off if you are to investigate yourself
October 30, 2007 at 10:43 pm #232589aahbarnes
Just wondering where I can find the levelling/metering unit? Is this in the vacinity of the matrix and pressure chamber?
Many thanks for your help.
October 30, 2007 at 10:45 pm #232590gegsy
Yea just below the matrix, it actually plugs into it
October 30, 2007 at 10:57 pm #232591clivejameson
Greg, isn’t that ‘1 minute left’ actually error code 1 which is no heating?
…in which case the most likely culprit is the heater itself 😉
Andrew, the only satisfactory way to confirm is to meter the heater, and if it’s faulty will need replacing…not cheap (circa £80 ) and it’s a big strip-down job to replace 😕
If you need professional help then try the link below, or if having a go yourself then unplug before doing anything :zap:
October 30, 2007 at 11:19 pm #232592gegsy
You may have something Clive 😀 Can’t do any harm in checking just with him saying it was doing it on the auto (turbidity sensor in action) and now it does it on all. My money is on crud 😉 You a betting man Clive 😆
October 30, 2007 at 11:23 pm #232593aahbarnes
Some good pointers here. If it is reset before each use it works ok, but I can’t see this lasting long.
October 30, 2007 at 11:37 pm #232594clivejameson
gegsy wrote: You a betting man Clive 😆
Wish i was…i tipped South Africa for the rugby 😕
