Neff S54E53X1GB/86 Dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff S54E53X1GB/86 Dishwasher
  • #83061
    folleyball
    Hi Guys
    The anti flood is continuously running on this dishwasher but there is no water in the base (and never has been).
    Am I missing something obvious here or is it circuit board trouble.
    #421622
    Re: Neff S54E53X1GB/86 Dishwasher
    there is a sensor section on the left that gets full of goo and blocks and causes the same problem
    go here http://www.neff-eshop.com/eshop/neff/gb … earch1.htm
    enter your Enr
    on diagram 4 its item 0420
    you will prob find the float is stuck up keeping pump on
    if so clean it and all will be ok
    folleyball
    Hi Dave
    Thanks for the quick reply.
    It was gunked up but the float was sat at the bottom. There is nothing pushing against the button on the micro switch.
    Could it be anything to do with the impellor flow meter?
    #421624
    no flow meter only works on fill
    things get more complicated from here
    on the main board all small components are switched by a device called a triac. they are used in lamp dimmers and the like to switch mains components from low voltage chips. these can go short and can be changed if you can solder
    take it you have checked the microswitch does work
