Neff S54M45X5GB/01 dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff S54M45X5GB/01 dishwasher
  • #50282
    geoffmackay
    This machine has low water pressure at spray arms. Because it was intergrated and 6.30 tonight I didnt pull it out. I assumed it would be a circ pump complete but see its made up in component form. Would i be correct in assuming motor or how often does impellor get a partial blockage? The cost of parts says I investigate further. The m/c is only out of 2 year warranty.
    Thanks Geoff
    #304263
    nomadPaul
    Geoff , as you look down into the sump , there is a hole at approx the 3 o’clock position. This is where the water gets sucked into the circ motor…have a poke around in this opening. I have had quite a few faults like this where a foreign object has blocked the hole and therefore restricted water flow…plastic packet rip-offs are a favourite .
    #304264
    smeghead
    Re: Neff S54M45X5GB/01 dishwasher
    hi
    possibly motor impellor split, you’ll hear the motor whirring but no pressure at spray arms. have a look at motor.
    clive
