Neff S54M45X5GB/01 dishwasher fill then empty
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Neff S54M45X5GB/01 dishwasher fill then empty
  • #82268
    tinfish
    The machine is filling then partially emptying then there’s a banging noise from the water it then fills a bit then repeats.
    I changed the water jug/flow sensor just in case it was related to the normal problem, but it made no change.
    Could it be a valve problem, or could it be the aquastop hose?
    Any help as always is appreciated
    Grant
    #419372
    Re: Neff S54M45X5GB/01 dishwasher fill then empty
    I think it more likely an issue with the pressure switch/transfer pipe to the tub. The banging you refer to, does that not relate to the red float switch going on and off, up and down?
    #419373
    tinfish
    That would be the pressure chamber then?
    I’ll see if they want to give it a go – it’s not an expensive part if it ends up living in the van for a while.
    #419374
    tinfish wrote:That would be the pressure chamber then?
    Not something you need to buy and fit but simply check out and clean if that is the fault…..
    #419375
    tinfish
    I’ll give it a go.
