Neff S54M45X5GB/01 filling problems
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Neff S54M45X5GB/01 filling problems
  • #49971
    malte
    Set on the rinse cycle
    The aquastop (Bitron 902) opens to let water in – fills for 2minutes, then the outlet valve opens and the pump pulses 3 times to empty out some water – this senario then repeats continuously until the door is opened. The “check water supply indicator” is lit and the programme has not started.
    Is the problem with the aquastop or is there a level fill sensor inside that is not switching the aquastop or could it be something else?
    #302899
    nomadPaul
    It’ll be the flow rate sensor ( impellor jug 424099 ) that sits in line with the inlet hose. You’ll find it as a whilte circular component on the left hand side between the water matrix and the end of the inlet hose.
    Power off when investigating.
    #302900
    malte
    Re: Neff S54M45X5GB/01 filling problems
    Thanks for the prompt reply and good info.
    Removed the flow rate sensor via the access panel for the inlet hose after unclipping from the water matrix.
    Was mechanically sound and spun freely, so cleaned contacts with switch cleaner and replaced.
    Auto cycle now works again, if it fails again i’ll replace it but I was made redundant in May so any saving is a good one.
    Thanks again
