Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Neff S54T09X1GB/06 Integ D/W
- This topic has 11 replies, 5 voices, and was last updated 16 years, 1 month ago by
Kez.
March 4, 2010 at 10:50 am #52975
Kez
ParticipantEngineer has been to look at Neff Integ DW this morning, it sometimes trips after about an hour but can trip at other times, has tested parts nothing obvious showing down to earth. Any ideas please? Cheers Kez
March 4, 2010 at 12:26 pm #313887Martin
ParticipantRe: Neff S54T09X1GB/06 Integ D/W
Mains Filter or Water Point device leaking under heater box both common faults.
March 4, 2010 at 4:51 pm #313888PINKY
Water points def favorite for this sort of fault
March 11, 2010 at 11:52 am #313889Kez
Thanks for your help, turned out the mains filter was split in half. Have fitted new one but now having trouble starting it. the light sensitive buttons seem ok if i remove board and operate but once fitted back through the fascia they seem very unresponsive? Any ideas would be gratefully received please? Cheers Kez
March 11, 2010 at 12:21 pm #313890Martin
I take it you have ‘reset’ the programme?
March 11, 2010 at 12:43 pm #313891Kez
Actually we havent! (New one on me) Please advise on what you have to do to reset the program. Cheers 😀
March 11, 2010 at 1:10 pm #313892Martin
You probably have in fact but just in case: –
To reset (cancel) a programme you just open the door and ‘Cancel Programme’ will be displayed. Press the minus (-) button and ‘Close Door’ will be displayed. Close the door and the drain pump activates for up to 60 secs then the buzzer sounds to indicate it’s completed. The programme has now ‘reset’. 🙂
As far as the button not responding…if the clear panel is dirty or is scratched it will cause touch sensor problems such as you mention.
March 11, 2010 at 5:04 pm #313893nomadPaul
ParticipantThis is one to check….as it has happened to me. Make sure your fingers are clean when you try and switch the appliance on . I had one where after a repair , neither myself or the customer’s husband could switch the thing on but the customer could. Turned out we had dirty fingers. I proved it to myself by putting a bit of kitchen roll round my finger and it worked….take away the paper and nothing !!!
A good lesson learned lol 🙂
March 12, 2010 at 6:47 pm #313894Cras
well tried your tip nomad and you are spot on ,wouldnt work with my grubby fingers but put my finger in a plastic bag and it worked every time ,then got the lady in office to try and hey presto works . Is this the first machine to be designed to be only operated by office workers at least this ones owned by a customer in the medical proffesion so we should be ok 😆 cras(on behalf of kez)
March 19, 2010 at 1:02 pm #313895Kez
Have taken this appliance back and all is working fine. But another question! The customer advises that when it went wrong initially the program that would normally take just under 2 hours was showing as 2hs 45 at the start. Since repair he says its still showing as a 2hr 45 program now?! Any idea if there is some sort of default setting that has been activated? Kind regards. Kez
March 19, 2010 at 1:19 pm #313896Martin
It defaults at around this time but after a couple of wash cycles that programme time should shorten. Provided of course that the turbidity sensor in the heater box isn’t gunged up? Or the heating element open circuit? 🙁
March 19, 2010 at 1:24 pm #313897Kez
What a font of knowledge you are! Thanks again. Kez
