Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Neff s54t09x1gb/21 not heating
- This topic has 11 replies, 5 voices, and was last updated 10 years, 10 months ago by
Washdisher.
June 12, 2015 at 2:39 pm #85233
Washdisher
ParticipantProblem is that the heater pressure switch is not closing. The pump motor sounds ok but when the door is opened mid cycle the residual amount of spray seems less than I’m generally used to. Also during a cycle there seems to be less of a whooshing noise than I’d expect. I’m wondering whether the pump motor is failing or could it be due to low water level? The water level is certainly above the filter screen so I doubt the pump is being starved of water. Any thoughts?
Derek
June 12, 2015 at 7:09 pm #428107smeghead
ParticipantRe: Neff s54t09x1gb/21 not heating
sounds like a fouled impeller in the wash pump.
worth a look,
CliveJune 14, 2015 at 12:54 am #428108Washdisher
Hi Clive,
Thanks for your input. My experience of dishwasher motors is that they work properly, not at all or very poorly, but if very poorly there is usually a distinct difference in the sound they make. What really has me wondering about this one is that the motor isn’t the usual Bosch style thing with a capacitor mounted on its side. I was wondering if there was something fundamentally different in its operation.
Derek
June 14, 2015 at 7:18 am #428109Martin
Did you check to see if the water point diverter valve is stuck in the closed position?
June 14, 2015 at 8:24 am #428110nomadPaul
The water, when full , should reach just above the bottom of the salt pot lid. If the levels are correct , I’d next be looking at a blockage in the wash motor/sump connection. Have a feel around down the channel at approx the 2 o’clock position in the sump. You may find that there is an obstruction there.
June 14, 2015 at 11:41 am #428111suedehead1
i would agree with faulty diverter valve.
June 15, 2015 at 9:06 am #428112Washdisher
Hi Martin,
Is this the water switch disc in the flow control assy mounted under the heater? Is it possible to check without removing the rinsing tank?
Derek
June 15, 2015 at 9:08 am #428113Washdisher
Also, there is water flow from both spray arms so if this were a flow control issue would this imply that the diverter valve (disc) is only partially closed?
June 15, 2015 at 11:43 am #428114Martin
ParticipantNeff s54t09x1gb/21 not heating
If you remove the 2 torx screws that attach top spray pipe to sump you can see the cam. If that is all clear then chances are the impeller is clogged with detritus. I use a torch and dentist mirror to peek inside the circl pump from the sump. Then use a hooked wire to poke out any rubbish from the impellor.
June 15, 2015 at 1:05 pm #428115Washdisher
Hi Martin,
Thanks v much for that. I’ll update once repaired.
Derek
June 15, 2015 at 6:43 pm #428116smeghead
Martin wrote:If you remove the 2 torx screws that attach top spray pipe to sump you can see the cam. If that is all clear then chances are the impeller is clogged with detritus. I use a torch and dentist mirror to peek inside the circl pump from the sump. Then use a hooked wire to poke out any rubbish from the impellor.
Martin , that’s exactly how I do it- great minds……
quite a common fault down our way, they never rinse the bleeding plates, nice little earner.
CliveJune 23, 2015 at 5:43 pm #428117Washdisher
Hi Martin,
Thanks v much for the info – I’ve now added two dental mirrors (£1.95 from Ebay) to my arsenal. Removed a shred of freezer bag from pump, via sump, and all’s well. Thanks also to all other contributors to this post.
Derek
