neff s5543x1 dishwasher
  • #45015
    suedehead1
    hi,
    the dishwasher wont fill up, the customer had installed a new washing machine but turned the water off to the dishwasher, after leaving it on for 8 hours he realised it wasnt working but when he turned the water on it wont fill.
    its one of these fill hoses with the solenoid at the valve end, the solenoid is ok but it wont fill up the valve isnt getting electricity, i checked everything but it wont fill any ideas?
    #283288
    Re: neff s5543x1 dishwasher
    8hrs? …… Probably inlet valve burnt out I should imagine?
    #283289
    suedehead1
    i checked the valve and it was ok.
    #283290
    suedehead1 wrote:the valve isnt getting electricity
    I think you’ve got an “Aquastop”? Give lots of trouble. Have you tried a search using the forum search engine and the above term?
    IIRC the supply to the valve in the aquastop is governed by a pressure switch or some such anti-flood device.
    Mike.
    #283291
    suedehead1 wrote:the valve isnt getting electricity,
    Ooops just spotted this. 😳
    No power to valve will probably mean that the triac to the valve on the PCB has gone west? 🙁
    #283292
    cornwell40
    Would it not time out before any big problems arose? 😕
    TC
    #283293
    suedehead1
    this triac to the valve is it replaceable?
    #283294
    No. 🙁
    #283295
    suedehead1
    hi,
    i sent the board to qer for repair it has came back with a couple of triacs replaced on it. i connected it up and there was a pop and one of the triacs has blown i am sending it back for repair but i was wondering why it has blown the triac.
    #283296
    deltra
    ask what the triacs are controling,valve,heater etc? that will be where the fault is.
    #283297
    Use a meter. Follow the tracks back to the edge connector. Wherever that goes, there’s your problem.
    suedehead1
    the triac is controling the water valve but it tested ok.
    #283299
    Simon46
    Would replace solenoid coil or wvalve. must be going short cct with mains applied.
    S.
    #283300
    suedehead1
    i got the pcb back for qer with an exernal fault note that they had forgotten to tell me the solenoid valve was faulty i changed it and refitted the pcb and it worked ok fingers crossed.
