Re: Neff S5543X1GB/13 Dishwasher no fill
RocLobsta,
Most likely the base of the machine is flooded 🙁 Best way to check this is to tip the machine backwards about 45 degrees to allow any water to drain out of the back (have a towel handy) *
Now if water does come out it usually means it has either an internal leak OR a water inlet blockage. Neither of which is considered a DIY fix, so you will need to call in one of us guys to take a look for you 🙂
Meanwhile you should find the machine will work quite normally, until it floods the base again 😯
* PULL THE PLUG OUT FIRST!!!!
