I have been to the above dishwasher. When I got there the drain pump was running continously and I could not reset the PCB. The PCB had blown so I replaced it. Everything works except now no drain pump durring the normal wash cycle. However if I activate the flood protection circuit the drain pump works.
I’ve checked that it heats, washes and i’ve double checked that the PCB was set correctly.
Colin, it’s important to inspect that blown PCB in an attempt to locate the component that caused it to blow in the first place? You run a great risk of blowing the new PCB if you don’t check carefully. Water Point devices (in the heater box unit) and Dispenser actuators are always suspect as well as inlet valve and heater too. Also, are you positive you have configured the new module correctly? (It cannot be done in position by the way). 😉
