neff s5943x2gb leaking
Home Forums Public Support Forums Help And Support Dishwasher Help Forum neff s5943x2gb leaking
  • #67136
    ashley600
    hi.
    having just removed the sides of the dishwasher i have found the leak is water coming from the hole in the top of the water distribtion tank on the left hand side,
    should this hole have a plug in it, or is the problem something more complex,
    thanks ash
    #366450
    ashley600
    Re: neff s5943x2gb leaking
    it also makes clunging noises when the programme starts may 4 or 5 times.
    don’t know if this help or not
    #366451
    That whole water inlet system and water level device will require removing and cleaning thoroughly to resolve your problem.
    #366452
    ashley600
    Do mean the water tank beneath the tub and salt chamber etc
    Or just the side tanks and the float valve and switches.
    I removed the side tank and gave it blast through with the garden hose
    I also took apart the float valve assembly stuck it all back together
    I still have the same leak from the top of the water tank??
    And same clung!!!
    #366453
    Then replace the “water tank”.
    #366454
    ashley600
    problem has been resolved at the cost of £4,
    for anyone who has the same problems as mine,
    a simple fix just reduce the water pressure going to the machine with either a pressure reducing valve or just a isaluation valve turned half way between open and closed.
    simples::
