Hi can anyone help with this dishwasher select the programs ok press start ,it then says close door but then nothing happens . The door lock tests ok and the pump is ok if you lift up the antiflood float. Any ideas why the thing is compleatly dead when you shut the door? Thanks.
Firstly reset the programme to clear the last programme setting and try again. Then you should get the various prog options to select/step through. Once selected it should register and advise you shut the door?
If none of that happens I can only figure the connections in the prog module have gone AWOL or worst still the Power module behind the RH side panel????
Thanks for the info . I can scroll through the programmes and select them all it then tells me to shut the door so i do and then zip nothing its dead and won,t do a thing. So its looking like the control board ,go on then tell me gently how much? Buy the way i have taken the control board off and no sighs of burnes or damage.
hi
Ive had a bosch doing similar and it was the PCB. On mine it was on the r/h base of appliance. Check model number again and I will route part number for you.
