neff SD13J1F
  • #71118
    cliffpat7
    I’ve got a neff dishwasher during mid cycle it stops filling and wash pump run but no wash . Wash pump OK( washes ) heater OK ( it heats)valve OK( it fills )empty pump OK ( empty water ) also checked float switch and level micro switches on left hand side .
    Run fast wash its about 25mins into cycle it stop empty water then restart to fill but wash motor fire on its like its on a drying cycle but will keep running of hrs . Is it a sensor fault or main PCB fault
    Sd13j1f
    S5943x2gb/37
    Fd8712000261
    Have check above ( problem is dishwasher is on 2-3 times a week about 4years old
    #380077
    linrew
    Re: neff SD13J1F
    check for a pressure chamber fault, could be clogged up and intermittently sticking on flood protection mode
    #380078
    cliffpat7
    Re: neff SD13J1F
    Machine fills starts cycle runs for most off cycle then empty .starts second part then freezes with wash motor runs not pump .flood mode not the fault .have check chamber and switches on left hand side .I’m a applaince repairman never seen this fault .hate blaming PCB as fault .thanks
    #380079
    linrew
    Re: neff SD13J1F
    when it starts second part of cycle, does it fill then wash pump or just wash pump? at end of first part is water hot or cold? is the thermostat and NTC on the heater ok? seems a strange one,
