Neff showing F04
  • #47430
    Not been out to this machine yet and don’t have an ENR number.
    Reading a few posts here suggests a pump fault but on page 8 of the fault code bible it has F04 as a motor (no tacho signal) fault. 😕
    So , which is it?
    Re: Neff showing F04
    Looking through the choices, it’s motor, no drain or heating when it shouldn’t. Assuming it’s a washer built by Bosch and not A SMEGGY one, in which case, in which case it’s an NTC error…….
    :snig:
    :p45:
    #293447
    Went this morning, twas the pump, coins, clips etc removed but pump not too happy, will need a new one if only I can find the part number.
    http://www.ukwhitegoods.co.uk/modules.p … ic&t=45742
    #293448
    iadom wrote:will need a new one if only I can find the part number.
    Neff W5340X0GB/15
    Genuine = 144483
    Qualtex = PMP250 (including filter body)
    Qualtex = PMP230 (askoll pump only)
    #293449
    Thanks Martin, must get these glasses fixed. 😆
