Neff single oven – Fan function & bottom lights not working.
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff single oven – Fan function & bottom lights not working.
  • #74629
    jackSOC
    Hi, I run a small oven cleaning business.
    I cleaned a single Neff oven (E-Nr B1644N0GB 03 FD 8511) last Thurs. The bulb had gone, so I replaced it with a 25w one.
    The customer contacted me on Sunday to say that when she used it for the first time, the bulb blew, thus resulting in the RCD tripping.
    I told her to remove the faulty bulb and then everything should work fine.
    Unfortunately she said the fan function and the 2 halogen lamps at the bottom of the oven (it’s one of those fancy Neffs) are now not working.
    What could be the cause of this? And how can it be fixed?
    Many thanks for your expertise,
    Jack
    #392327
    SAMURI
    Re: Neff single oven – Fan function & bottom lights not work
    Has the customer reset the clock with a time?
    if the clock is not set with a time the oven will not work
    Bob
    #392328
    Hate to tell you this but I suspect the PC board has blown! 🙁
    #392329
    jackSOC
    The clock has been set yes.
    Can the PC board be replaced Martin?
    Thanks for your help.
    #392330
    jackSOC
    And could a blown bulb cause this?
    Thanks.
