neff slide & hide oven doors
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries neff slide & hide oven doors
  • #85758
    smeghead
    Anyone got experience on these, Mod.B45E42NOGB/01
    haven’t seen it yet, but guy says he thinks a wire has broken as the handle doesn’t flip out on opening door.
    Webshop gives a handle bearing kit for £104.
    TBH I don’t even know how the door comes off the oven –
    any help appreciated before I dive in
    Clive.
    #429485
    nomadPaul
    Re: neff slide & hide oven doors
    Depends on the year. Getting the door off is easier than getting it back on again ! If the customer has the instruction booklet that shows how to remove and refit the door. You could download a copy if the booklet isn’t available.
    Basically you open the door approx 30* which exposes 2 large locking screws at the bottom. These need to be rotated 45* to lock the rollers in place. There may also be 2 locking collars either side of the door where the locating lugs sit.
    This is where you might have a problem as the locating lugs rotate when you rotate the handle but if the wire has broken , the lugs won’t turn so you may have trouble releasing the door ! Sorry to be a bit doom and gloom but they’re quite a pain in the ‘arris .
    #429486
    smeghead
    ok , thanks for the info, Sounds a bit of a pain as you say.
    Clive
