Neff slide n hide door cable needed – B45M52N3GB/04
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Neff slide n hide door cable needed – B45M52N3GB/04
  • #99835
    twicknix
    The wire cable inside the door (there are two of them – one on each side) attached to the springs and looped over the handle and side bushing. Seeing that it is prone to snapping after many sliding and hiding the door that I would have thought the cable would be readily available as replacement stock but no.
    I have replaced door cable in the past and for some strange reason that it does not appear to be listed as replacement part. I will look for the old job sheet where I replaced the door cable at different address to see if there is a part number but it might be quicker here which is worth a try. The oven is only 7 years old and surely that there should be parts for it? Can anyone direct me to the right place to get replacement door cable? Thank you
    #478091
    last and only one i did i had to change the bearing at the top of the door. that was over 2 years ago and no seperate cables then
    should come with part no 734654. not cheap at a retail price of £126
    twicknix
    electrofix wrote:last and only one i did i had to change the bearing at the top of the door. that was over 2 years ago and no seperate cables then
    Where do I get this part? The number is not listed elsewhere such as Connect and ASWO.
    #478093
    twicknix
    Managed to look closer and you are right that it is part of the handle and found the previous job that I did which confirmed on what you said about changing the bearing at the top. Easier to source it from ASWO than from Connect. Thank you for your help.
