Neff Sliding Door ‘pops off’ when pulled at a slight angle
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff Sliding Door ‘pops off’ when pulled at a slight angle
  • #100752
    holland141
    We have a 10 years old Neff – model B45E42N0GB
    The door has started to pop-off the runners, and unfortunately this has also smashed the inside glass.
    I’ve looked at the sliding mechanism, and it all seems OK. I’ve reattached the door, made sure the two plastic locks are in place, and it seems to slide back and forth OK. However, if I slide it an pull it slightly to one side, the runners pop out of the track (with quite a twang – that must have been what caused the glass to break). It almost seems as if the oven has got slightly wider that the door, or maybe the black plastic runners (in the picture) have warn to the point that they dont fit snug.
    Anyone recognise this problem? Any ideas? I dont want to replace the door glass until I know the sliding mechanism is safe.
    Thanks in advance
    Steve[IMG2=JSON]{“data-align”:”none”,”data-linktype”:”1″,”data-linkurl”:”https://photos.app.goo.gl/2p8Fzo5dX6fz4Ftu7″,”data-size”:”full”,”title”:”Hinge”,”src”:”https://photos.app.goo.gl/2p8Fzo5dX6fz4Ftu7″}[/IMG2]
    My photo of door hinge : https://photos.app.goo.gl/2p8Fzo5dX6fz4Ftu7
    Neff spare…..https://www.neff-home.com/ie/supportdetail/product/B45E42N0GB/01#/Tabs=section-spareparts/Togglebox=tb0704/
    #482069
    there are 2 locks
    one to hold the mech in the correct position to replace the door
    the other locks the door on so you can release the first one to slide it up and down
    holland141
    Hi. Thanks Dave.
    I’m pretty sure I’ve seatedt teh door correctly. I’ve twisted the plastic locks on the stansion so the door cannot be lifted out, and opened the locks on the mech so it can be slided back and forth. The mechanism works well if I pull straight back and forward, but if I pull slightly left or right the door pops off the runners (the stantion lock is stil on so even once is popped off the runners, you cant lift the door off. Make sense?
    Steve
    #482071
    never had one do this
    is the bar between the 2 support bearings look ok
    there is something allowing the door to over twist and pop out of the runners
