Neff s5943x2gb/41 its one with the large plastic side tank, theres no impellor jug and the transfer hose and pressure chamber are clear. it fills up but doesn’t release the water from the right hand side of the tank and just keeps filling making the float lift and activate the drain pump. ive changed the valve on the side of the salt pot but no joy.
go to page 4
see item 0411 this item is the water level switch. as unit fills you can watch the bar operating the switch. check switch and if its working check the wiring back to the timer
it may not stop filling as the switch operated but should stop soon after
hilly wrote:ive changed the valve on the side of the salt pot but no joy.
Then it sounds to me you’ve changed the wrong valve. The ‘outlet valve’ (00166874) needs changing and that is the one on the right of the ‘salt valve’.
