Neff K4316X4GB/04 – stopped cooling – replaced relay – no better – when fridge is turned on compressor runs for about 10 sections then stops – after say another 10 sections you can hear the system trying to start but it doesnt – the readings across the compressor pins are approx. 35, 21and 16 ohms – any ideas as to whats wrong and what to do – the fridge is about 10 yrs old – Many thanks
Thanks for that Dave – is that based upon the readings that I obtained across the compressor pins?
Do you know what sort of reading should be obtained?
Thank you
