W4380X1g
Keeps going into Pause and start light flashes,
Press start and starts again,
This machine is intergratted and it looks like its going to be hard to get out.
A long run on the drain hose behind several units and connected under sink.And a kickplate jammed in position
And they wont have it done if its a big repair.
It drains fine, Could it be the heater.
Any ideas.
You’ll need to set it onto the last position on the dial to clear what is essentially an error code. Turn off then select any programme to see what happens? I’m not sure personally but the likely suspect is the motor (or the heater of course. :wink:) etc.
Whatever, it has to come out to investigate I’m afraid, no magic bullet solution on this one…sorry!
