Neff T1872NO/01 hob.
  • #50027
    aqualectric
    Neff T1872NO/01 ceramic hob. FD 8307.
    This hob uses the touch sensitive control module below the glass. Plates check out OK, but 2 do not function. Module shows no signs of burning and the wiring is intact. I am pretty sure it’s the module ATM, but just looked up the price…… 😯 😯 £243 from BSH.
    Moral support required!! 😉
    Steve.
    #303071
    Jonah
    Re: Neff T1872NO/01 hob.
    Hi Steve, has it got a seperate filter card for the mains supply, I had a Neff induction hob with R/H side not working and it was the filter card not the touch control faulty
    #303072
    aqualectric
    Thanks, Jonah. Checked the parts list and a filter card is not listed. To be honest, the hob is very basic internally; there are the hotplates, the wiring, the terminal block and the module control. That’s about it.
    Is the filter card in the terminal block housing or in the module or is it separately mounted? As I say, it’s not on the parts list……. 😕
    Cheers,
    Steve.
    #303073
    Jonah
    I reckon it has to be touch control if a filter card is not listed, TBH they are normally only on induction hobs not normal ceramics, BSH parts are really expensive got the same problem with a built in microwave gonna cost about £350 to repair it 😯
    #303074
    suedehead1
    raising an old thread, i went to one of these today and one of the hotplates isnt working the botttom of the hob cannot be removed because of bad installation, and the hob is stuck to the worktop with sealant, anyone got any ideas how it can be repaired please.
    #303075
    Jonah
    Untill you get it out there ain’t much you can do, typical DIY install by the sound of it mate :bang:
    #303076
    suedehead1
    thanks for the reply, just as i thought whoever installed it has not left access to the underside, the hotplate required is listed at £170 so that should be enough to put them off.
