help! touch control hob, the hob is doing odd things.it turns itself off. e/codes flash. you cant turn it off. you can set it to a temp rings will not come on.then you get no control at all.
On these models , it’s probably the LHS PC board starting to fail. This board has the mains power coming in to it. I’ve changed a few . Its worth making sure of the installation when you visit as they need plenty of ventilation down the front where the fan vents are.
