Neff T4483 induction hob
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Neff T4483 induction hob
  • #45911
    76
    Hi Guys,
    currently on with a install of a kitchen and they want the above hob which has been ordered. The question is what size supply will it need, as if it needs a seperate 30 amp we need to get this in before we carry on with the fitting.
    Someone suggested it would? Searched the internet but no joy!
    Jo
    #287597
    don
    Re: Neff T4483 induction hob
    Hi Jo
    According to the Neff catalogue the connected load is 7.29 kw however as you have a “boost” option on each ring the maximum rating then becomes 9.2 kw. Which equates to 38.3 amps if my calculation is correct 😉
    HTH
    Don
    #287598
    76
    Thanks Don,
    the sparkies started to run a 6mm supply, found some info on other brands but was struggling with technical info from Neff!
    Many Thanks
    Jo
