Neff U1420N0GB/01
  • #89310
    franz
    Hi, does anyone know how to split the oven door to replace the hinges, looks like it’s held on with silicon. I’ve removed all screws but door is stuck solid. Any help would be appreciated.
    Franz
    #440972
    Kentish
    Re: Neff U1420N0GB/01
    Without seeing if to remind me of its layout, they only silicon bond the inner glass to the inner door panel. They do have an silicon type sealing strip between the outer glass and door panel. Teasing it apart with a flat blade is easy, and from memory starting at the top.
    #440973
    Yes the sealing strip (00262192) can be prised apart and replaced though Neff want silly money for a what is just a sticky strip.
    #440974
    franz
    Thanks for the replies guys, will order strip.
    Franz
    #440975
    Kentish
    I dont replace the sealing strip, as it always comes away nicely from the door panel edge. It will reseal itself, so save your money and time.
