Hiya,
This oven blows the mains rcd when you turn the fan oven on. The grill functions correctly.
It was working perfectly until a new main fuse board was put it. The electrician says it is a fault with the cooker.
It blows immediately when you turn the main oven dial on and trips the lights with the cooker.
On the fuse board there is a dedicated fuse for the cooker but it does not blow, just the rcd next to it which as mentioned takes out the lights.
Any ideas?
