The handle on my oven broke and I have bought a new one from bsh. Problem is I can’t get the door apart to fit it.
Removed the screws from the inner panel, but now can’t get the glass outer panel away from the inner.
Please could somebody advise how to do this and if they are bonded, how do I re-bond them after fitting the handle.
As far as i know
Once you have taken screws out of handle, the glass will prise away(gently) from the main metal door frame at the top.
Then gently seperate the two in an upward motion as the clips bonded to the glass, hook onto door hinges.
Thanks for advice.
Had to cut the glass away from the seals in the end by sliding knife around flat to the glass. Now have separated the pieces and installed the handle. Will have to order new seal strips from bsh.
Thanks again.
