Neff U1421 Oven
  • #24008
    T600
    Hi.
    The main oven door on our Neff U1421 is no longer closing properly. This seems to be gradually getting worse over time. Initially it just looked a few mm open, but now it’s almost 2cm.
    I suspect the springs are no longer strong enough to keep the door closed.
    I don’t believe it’s the mounts as when open the door is still horizontal, and I’m not aware of the door having ever been over stressed when opened. And there’s no sign of distortion on the oven door or frame.
    Is it likely that these hinges have weakend to the extent that they are causing this problem? They look easy to replace, in fact I did remove them to inspect them, but can’t see any adjustment so just had to re-assemble the door.
    I see from other threads, where the door has been sat on for example, the mounts may need replacing. I don’t think this is the case here, but if they do need to be replaced it looks like a much more difficult job.
    The oven is almost 4 years old by the way.
    Any advice very much welcomed. Thanks.
    #200201
    gegsy
    Re: Neff U1421 Oven
    In order to assist you further, we would require the full model number ie U1421…. This can be found around the main oven opening when door is open, usually on a metal plate.
    T600
    Re: Neff U1421 Oven
    Hi Greg.
    The full code is U1421N2GB/01
    Cheers,
    Tony
    #200203
    gegsy
    Re: Neff U1421 Oven
    I would imagine that the hinges spring tension has gone and as you rightly said , there are no adjustments.
    Parts you will need
    Left hand Hinge (looking straight at door on oven) – 260797
    Right hand hinge (looking straight at door on oven) – 260798
    Both available from spares@ukwhitegoods.co.uk and cost app £10 each + costs
    T600
    Re: Neff U1421 Oven
    Thanks gegsy, I thought so, but it’s good to have it confirmed by someone more knowledgeable! And thanks for looking up part numbers. I’ll order those bits now.
    Best regards,
    Tony
    #200205
    gegsy
    Re: Neff U1421 Oven
    No problem Tony, any hassle let us know.
    T600
    Re: Neff U1421 Oven
    Hi again. Just thought I’d confirm that this is all sorted.
    Orded the hinges as you suggested and they arrived today. I fitted them in a few minutes, and the door closes perfectly. Result.
    So thanks again for your assistance Greg.
    Tony
    #200207
    gegsy
    Re: Neff U1421 Oven
    Hi Tony
    Thank you for coming back to us. Its nice to know the end results most times we get no update, which is a shame.
    Thanks again.
    Regards
